StarTech.com 30 ft USB 3.0 A to B Cable M/M
Quicklinx: BJWZWS00 Mfr#: USB3SAB10M
Length: 10m
More than 50 in stock
£91.34 ex VAT
£109.60 inc VAT
Connect USB 3.0 devices up to 10m away, with no signal loss. You don't need to be limited by a standard-sized USB cable. This active USB 3.1 Gen 1 (5 Gbps) cable, better known as a USB 3.0 cable, lets you position your USB Type-B peripherals where you need them, up to 10 meters away from your computer.
Now, you can locate USB devices such as portable hard drives and external video capture devices to make better use of your workspace. This 10-meter (30-foot) cable has a built-in equalizing chip that delivers a reliable connection, with no signal loss, beyond the 3-meter limit of standard USB 3.0 cables.
StarTech.com 30ft Active USB 3.0 USB-A to USB-B Cable - M/M - USB 3.1 Gen 1 - USB cable - 10 m
USB cable
Double shielded
Molded
Length
10 m
Connector
9 pin USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
USB cable
Double shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Molded
Length
10 m
Connector
USB 3.0, RoHS
Length: 10m
Price Range Ex VAT: 50 - 100
