Product
StarTech.com 30 ft DisplayPort Cable with Latches - M/M
Quicklinx: 7NXHWS00 Mfr#: DISPLPORT30L
Length: 9.1m
18 in stock
£62.97 ex VAT
£75.56 inc VAT
The DISPLPORT30L 30ft DisplayPort Cable supports a maximum bandwidth of 10.8 Gbps, and is capable of providing higher performance than either HDMI or dual link DVI and supporting next generation multimedia applications with a maximum resolution capability of up to WQXGA (2560×1600).
The cable features small, USB-sized latching connectors, with support for 2-way display connectivity and optional audio support. This 30-foot DisplayPort cable is both HDCP and DPCP capable, ensuring that digitally protected content is displayed properly on the connected display.
StarTech.com 30 ft DisplayPort Cable with Latches - M/M - DisplayPort cable - 9.1 m
DisplayPort cable
Shielded
Latched, molded
Length
9.1 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS, NEC-CMG
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
26
Plated Connector
Nickel
Latched, molded
Length
9.1 m
Connector
20 pin DisplayPort - male
RoHS, NEC-CMG
7NXH StarTech.com 6 ft DisplayPort Video Extension Cable - M/F In Stock £22.18
7NXH StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £11.08
Length: 9.1m
Price Range Ex VAT: 50 - 100
