StarTech.com 30 ft Coax High Resolution Monitor VGA Cable - HD15 M/M
Quicklinx: 76MYWS00 Mfr#: MXT101MMHQ30
This 30ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male to male coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 30 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - 30ft HD15 to HD15 Cable - 30ft VGA Monitor Cable (MXT101MMHQ30) - VGA cable - 9.1 m
VGA cable
Triple shielded twisted pair coaxial
Molded, ferrite bead
Length
9.1 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
UL 2919, RoHS, NEC-CMG
P/N: CDP2VGA, CDP2VGAFC, DVI2VGAE, DVIVGAMF, DVIVGAMFBK, HD2VGAA2, HD2VGAE2, HD2VGAMICRO, MCHD2VGAE2, MDP2VGA, MDP2VGA2, MDP2VGAW, MNHD2VGAE2, USB2VGAE2, USB2VGAE3, USB2VGAPRO2, USB32VGAES, USB32VGAPRO
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
9.1 m
Connector
