Product
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable
Quicklinx: 9PRFWS00 Mfr#: ST3300GU3B
Type: USB Hub
Ports: 3
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
11 in stock
£35.66 ex VAT
£42.79 inc VAT
Add 3 external USB 3.0 ports with UASP and a Gigabit Ethernet port to your Ultrabook or laptop through a single USB 3.0 port. The ST3300GU3B Portable USB 3.0 Hub features an integrated GbE port, enabling you to expand your laptop connectivity by adding three external USB 3.0 ports, as well as a Gigabit network port via a single USB 3.0 connection. This hub is an ideal laptop accessory for your Microsoft Surface Pro 4, Surface Pro 3, Surface Book, Dell XPS 13, and many other devices.
The hub merges Gigabit network support and USB 3.0 hub access into lightweight yet sturdy aluminum casing, providing vital connectivity ports that are often limited or nonexistent on modern mobile computers, while remaining compact and travel-friendly. Plus, with an attached USB 3.0 host connection cable there's no need to carry a separate cable with you, so you can tuck the hub neatly into your laptop bag for maximum portability.
For faster and more consistent network connections, the integrated Ethernet port leverages the 5 Gbps capabilities of the USB 3.0 interface to provide wired Gigabit access that is fully compatible with IEEE 802.3/u/ab standards.
An ideal laptop accessory, this mobile USB hub is great for connecting low-power peripherals like a mouse, keyboard or USB flash drive, and also includes a universal power adapter for connecting devices.
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - hub - 3 ports
Hub - 3 ports
Subtype
USB
Ports
3 x SuperSpeed USB 3.0 + 1 x 10/100/1000
Auto-uplink (auto MDI/MDI-X), full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
AC 120/230 V
4.3 cm x 8.7 cm x 1.4 cm
61 g
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Linux 2.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
2 years warranty
Hub - 3 ports
Enclosure Type
Desktop
Subtype
USB
Ports
X ASIX AX88179
Status Indicators
Link/activity
3 x USB 3.0 Type A , 1 x 1000Base-T RJ-45
External power adapter
AC 120/230 V
FCC, RoHS
Software Included
Drivers & Utilities
4.3 cm
8.7 cm
1.4 cm
61 g
50 °C
0 - 85% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
75 °C
9PRF StarTech.com 6 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £3.35
9PRF StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £22.66
9PRF StarTech.com 6 ft Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.10
9PRF StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £5.73
9PRF StarTech.com 1 Port Flush Mount ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £17.38
9PRF StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power In Stock £18.53
9PRF StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £71.38
9PRF StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power In Stock £21.21
9PRF StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £35.66
9PRF StarTech.com DC Power Adapter - 5V, 2A In Stock £12.19
Type: USB Hub
Ports: 3
Price Range Ex VAT: 0 - 50
