This PCI USB 2.0 Adapter Card adds two external USB 2.0 ports as well as one internal USB 2.0 port, through simple installation in a single PCI slot. The PCI USB 2.0 card supports Plug and Play installation as well as hot-swappable connectivity with USB 2.0 devices, ensuring convenient, hassle-free connections without having to reboot the computer. The PCI USB 2.0 adapter card features a low-profile design that's suited for small form factor cases.
- StarTech.com 3 Port PCI Low Profile High Speed USB 2.0 Adapter Card - USB adapter - PCI - 3 ports
- USB adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI
- Ports Qty
- 3 ports
- Data Link Protocol
- USB, USB 2.0
- Data Transfer Rate
- 480 Mbps
- System Requirements
- Linux, Microsoft Windows 2000, Apple MacOS X 10.2.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- Limited lifetime warranty
- USB adapter - 3 ports
- Form Factor
- PCI
- Connectivity Technology
- Wired
- USB, USB 2.0
- 480 Mbps
- 2 x USB 2.0 - 4 pin USB Type A (external) , 1 x USB 2.0 - 4 pin USB Type A (internal)
- Compatible Slots
- 1 x PCI - low-profile
- WHQL, FCC, RoHS
- OS Required
- Limited warranty - lifetime
