StarTech.com 3 Port HDMI Auto Switch w/ IR Remote Control
Quicklinx: 8SFZWS00 Mfr#: VS123HD
Share a single HDMI display or projector between three HDMI video sources - with device priority and signal loss switching. The VS123HD 3-port HDMI Auto Switch features three prioritized HDMI input ports. If the active HDMI source is turned off, disconnected, or otherwise lost, the switch automatically selects the next available HDMI signal as the priority output, ensuring the display is always receiving a signal.
The automatic switch includes an IR Remote Control, so you'll be able to share an HD projector or display between three HDMI audio/video sources, with the option to manually control the switch from a distance or through the easy-to-use front panel toggle button.
Ideal for High-Definition applications, this 3-in/1-out HDMI switch supports true High-Definition 1080p resolutions (WUXGA/1920x1200 from PC/computer) as well as 7.1 Surround Sound audio, ensuring the best possible multimedia experience from connected devices.
StarTech.com 3 Port HDMI Auto Switch w/ IR Remote Control - video/audio switch - 3 ports
Video/audio switch - 3 ports
Subtype
HDMI
Ports
3 x HDMI
HDCP compliant
5.5 cm x 8.1 cm x 2.5 cm
99.5 g
Enclosure Type
Desktop
Subtype
HDMI
Ports
3 x HDMI
Max Resolution
1920 x 1200 / 1080p
HDCP compliant
Status Indicators
Port status
3 x HDMI input , 1 x HDMI output
Remote control
1 x remote control cable
FCC, RoHS
5.5 cm
8.1 cm
2.5 cm
99.5 g
70 °C
10 - 85%
Min Storage Temperature
-65 °C
Max Storage Temperature
150 °C
8SFZ StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.37
