Add 2 FireWire800 and 1 FireWire400 port to any desktop with a PCI slot. This 3 port PCI IEEE 1394a/b FireWire adapter card turns a PCI slot into two FireWire 800 (IEEE 1394b) ports and one FireWire 400 (IEEE 1394a) port - a cost-effective solution that lets you connect FireWire 800 devices as well as older FireWire 400 devices to your desktop computer.
A versatile FireWire solution, the adapter card works in both 5v and 3.3v PCI slots and in 64-bit and 32-bit environments, making it easy to create a high-speed laptop digital media center, or connect demanding FireWire peripheral devices such as portable hard drives, DV camcorders, digital cameras and CD-RW/DVD-RW drives. This high quality adapter card is designed to provide reliable FireWire 800 and FireWire 400 connections.
- StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter - FireWire adapter - PCIe - 2 ports
- FireWire adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- 12 cm x 9 cm x 1.8 cm
- 46 g
- Ports Qty
- 2 ports
- Auxiliary Ports
- 1 x IEEE 1394 (FireWire)
- Data Link Protocol
- FireWire 800
- Data Transfer Rate
- 800 Mbps
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Linux 3.5.x or later LTS versions only, Apple macOS 13.0
- Limited lifetime warranty
- FireWire adapter - 2 ports
- Form Factor
- PCI Express x1
- Connectivity Technology
- Wired
- IEEE 1394b (FireWire 800)
- Auxiliary Ports
- 800 Mbps
- 2 x FireWire 800 - 9 pin FireWire 800 , 1 x FireWire - 6 PIN FireWire
- Compatible Slots
- 1 x PCI Express x1
- FCC, RoHS
- OS Required
- 12 cm
- 9 cm
- 1.8 cm
- 46 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 0 - 90%
StarTech.com 3 Port 2b 1a PCI 1394b FireWire Adapter Card with DV Editing Kit | In Stock | £48.06 |
StarTech.com 2 Port ExpressCard 1394b FireWire Laptop Adapter Card | In Stock | £43.59 |
StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter | In Stock | £55.09 |
StarTech.com 3 Port 2b 1a 1394 Mini PCI Express FireWire Card Adapter | In Stock | £68.92 |
StarTech.com 6 ft IEEE-1394 Firewire Cable 9-6 M/M | In Stock | £7.62 |
StarTech.com 2 Port PCI Express FireWire Card - 1394a Firewire | In Stock | £26.39 |
