Add 2 native FireWire 800 ports to your computer through a PCI Express expansion slot. This 3 Port PCI Express FireWire adapter card can be installed in a PCI Express slot to add two IEEE1394b (FireWire 800 - 9 pin) ports and one IEEE1394a (FireWire 400 - 6 pin) port, providing broad compatibility with a wide range of FireWire devices (e.g. DV camcorders, external hard drives, digital cameras, etc.).
The 2b, 1a card features a native (single chip) PCI Express chipset - resulting in faster, more reliable and cost effective performance than expansion cards that utilize a "bridge" chip.
- StarTech.com 3 Port 2b 1a 1394 PCI Express FireWire Card Adapter - 1394 FW PCIe FireWire 800 / 400 Card (PEX1394B3) - FireWire adapter - PCIe - 2 ports
- FireWire adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- Bus Voltage
- 3.3 V
- 1.8 cm x 8.5 cm x 12 cm
- 48 g
- Ports Qty
- 2 ports
- Auxiliary Ports
- 1 x IEEE 1394 (FireWire)
- Data Link Protocol
- FireWire 800
- Data Transfer Rate
- 800 Mbps
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Linux 3.5.x or later LTS versions only, Apple macOS 13.0
- Limited lifetime warranty
- Designed For
- P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
- FireWire adapter - 2 ports
- Form Factor
- Plug-in card
- PCI Express x1
- Bus Voltage
- 3.3 V
- Connectivity Technology
- Wired
- IEEE 1394b (FireWire 800)
- Auxiliary Ports
- 800 Mbps
- 2 x FireWire 800 - 9 pin FireWire 800 , 1 x FireWire - 6 PIN FireWire
- Compatible Slots
- 1 x PCI Express x1
- Cables Included
- 1 x IEEE 1394b cable (external) - 1.5 m
- UL, FCC
- Software Included
- Drivers & Utilities
- OS Required
- 1.8 cm
- 8.5 cm
- 12 cm
- 48 g
- Limited warranty - lifetime
- Designed For
StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter | In Stock | £55.09 |
StarTech.com 6 ft IEEE-1394 Firewire Cable 9-6 M/M | In Stock | £9.46 |
StarTech.com 10 ft 1394b Firewire 800 Cable 9-9 M/M | In Stock | £14.70 |
StarTech.com 2 Port PCI Express FireWire Card - 1394a Firewire | In Stock | £26.39 |
