StarTech.com 3 Port 2b 1a 1394 Mini PCI Express FireWire Card Adapter
Quicklinx: 7NZQWS00 Mfr#: MPEX1394B3
Type: FireWire adapter
Compatibility: PC
Interface: PCI Express Mini Card
  • Windows 8 (32/64 bits)
£58.91 ex VAT
£70.69 inc VAT
Add 2 FireWire-800 and 1 FireWire-400 port through a Mini PCI Express slot. The MPEX1394B3 3-Port Mini PCI Express FireWire Card is a PCI Express to FireWire-800/FireWire-400 adapter that enables you to add external FireWire connectivity on very small form factor or embedded systems. The PCIe FireWire card provides two FireWire-800 ports and one FireWire-400 port, this adapter card supports the latest external FireWire storage devices at data transfer speeds of up to 800 Mbps. Using the Mini PCI Express (Mini Card) form factor, this adapter card is designed for use in the latest very small form factor computer systems, such as Mini-ITX or custom embedded solutions where a full-sized PCI Express card would not fit.
StarTech.com 3 Port 2b 1a 1394 Mini PCI Express FireWire Card Adapter - FireWire adapter - 2 ports
FireWire adapter
Plug-in card
Interface (Bus) Type
3 cm x 5 cm x 0.4 cm
6.8 g
Ports Qty
2 ports
Auxiliary Ports
1 x IEEE 1394 (FireWire)
FireWire 800
Data Transfer Rate
800 Mbps
Linux, Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Plug-in card
Wired
IEEE 1394b (FireWire 800)
Auxiliary Ports
Data Transfer Rate
800 Mbps
2 x FireWire 800 - 9 pin FireWire 800 , 1 x FireWire - 6 PIN FireWire
Compatible Slots
1 x PCI Express Mini Card - full-length
FCC, RoHS
3 cm
5 cm
0.4 cm
6.8 g
70 °C
7NZQ StarTech.com 6ft IEEE-1394 FireWire Cable 6-6 M/M In Stock £4.39
7NZQ StarTech.com 10 ft IEEE-1394 FireWire Cable 6-6 M/M In Stock £5.48
7NZQ StarTech.com 6 ft IEEE-1394 Firewire Cable 9-6 M/M In Stock £7.27
7NZQ StarTech.com 10 ft 1394b Firewire 800 Cable 9-9 M/M In Stock £15.17
Compatibility: PC
Price Range Ex VAT: 50 - 100
