StarTech.com 3 ft USB Y Cable for External Hard Drive - USB A to mini B
Quicklinx: 76QTWS00 Mfr#: USB2HABMY3
Length: 91cm
Select:
£3.70 ex VAT
£4.44 inc VAT
Connect and power your external mini-USB equipped hard drive through two standard USB ports on your computer. The USB2HABMY3 3 ft USB-A to Mini-B Y cable features two USB-A male connectors and a single USB Mini-B male connector - an ideal solution for providing additional power to your mini-USB external hard drive by connecting to two USB-A ports on your computer or laptop.
Especially valuable in situations where a single USB 2.0 port may not offer sufficient power to external hard drives, the USB2HABMY3 can be connected to two ports on one PC to increase the power output to power the external device.
StarTech.com 3 ft USB Y Cable for External Hard Drive - USB A to mini B - USB cable - USB (M) to mini-USB Type B (M) - USB 2.0 - Black (USB2HABMY3) - USB cable - 91 cm
USB cable
Length
91 cm
Connector
2 x 4 pin USB Type A - male
Connector (Second End)
Mini-USB Type B - male
USB / USB 2.0
P/N: SAT1810U2, SLMSOPTB, PEXUSB7LP
USB cable
American Wire Gauge (AWG)
24/28
Length
91 cm
Connector
USB / USB 2.0, RoHS
StarTech.com 1.8in USB to Micro SATA Hard Drive Enclosure, 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card, USB to Slimline SATA CD/DVD Optical Drive Enclosure
76QT StarTech.com 6 ft Mini USB Cable - A to Mini B In Stock £3.18
76QT StarTech.com 3 ft Mini USB 2.0 Cable - A to Mini B In Stock £3.19
76QT StarTech.com 10 ft USB 2.0 Cable - USB A to Mini B In Stock £3.34
76QT StarTech.com Mini USB to Micro USB Adapter In Stock £4.98
76QT StarTech.com 1 ft Mini USB 2.0 Cable - A to Mini B - M/M In Stock £3.17
76QT StarTech.com 3 ft USB Y Cable for External Hard Drive - USB A to mini B In Stock £3.70
76QT StarTech.com 6 ft USB Y Cable for External Hard Drive - USB A to mini B In Stock £3.90
76QT StarTech.com 1ft Micro USB Cable - A to Micro B In Stock £3.70
Length: 91cm
Price Range Ex VAT: 0 - 50
