The USBHAUBMB3 3-foot USB to micro USB and mini USB combo cable provides 1 USB "A" male connector, 1 micro USB "B" connector and 1 mini USB "B" connector, letting you connect mobile devices that use a micro or mini USB connector to a USB-capable computer for charging, data synchronization and file transfers.
This 2-in-1 multifunction USB to mini/micro USB cable (USB combo cable) is the perfect solution for connecting your mini USB or micro USB device while avoiding the hassle of swapping in and out between 2 separate cables. The USB combo cable ensures dependable, long-lasting connections between mini/micro USB and standard USB devices.
- StarTech.com USB to Micro USB and Mini USB Combo Cable - USB cable - 91 cm
- USB cable
- Length
- 91 cm
- Connectors
- 4 pin USB Type A - male
- Connectors (Second End)
- 5 pin Micro-USB Type B - male , Mini-USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB
- USB cable
- American Wire Gauge (AWG)
- 26/28
- Length
- 91 cm
- Black
- Connectors
- USB / USB 2.0, RoHS
- Designed For
