Product
StarTech.com 3 ft USB to Micro USB and Mini USB Combo Cable - A to B
Quicklinx: 7P47WS00 Mfr#: USBHAUBMB3
The USBHAUBMB3 3-foot USB to micro USB and mini USB combo cable provides 1 USB "A" male connector, 1 micro USB "B" connector and 1 mini USB "B" connector, letting you connect mobile devices that use a micro or mini USB connector to a USB-capable computer for charging, data synchronization and file transfers.
This 2-in-1 multifunction USB to mini/micro USB cable (USB combo cable) is the perfect solution for connecting your mini USB or micro USB device while avoiding the hassle of swapping in and out between 2 separate cables. The USB combo cable ensures dependable, long-lasting connections between mini/micro USB and standard USB devices.
StarTech.com USB to Micro USB and Mini USB Combo Cable - USB cable - 91 cm
USB cable
Length
91 cm
Connectors
4 pin USB Type A - male
Connectors (Second End)
5 pin Micro-USB Type B - male , Mini-USB Type B - male
USB / USB 2.0
USB cable
American Wire Gauge (AWG)
26/28
Length
91 cm
Connectors
USB / USB 2.0, RoHS
