StarTech.com 3 ft SuperSpeed USB 3.0 to eSATA Cable Adapter
Quicklinx: 7P42WS00 Mfr#: USB3S2ESATA
The USB3S2ESATA USB 3.0 to eSATA Adapter Cable lets you connect an external SATA (eSATA) device or enclosure to a host computer through USB 3.0, in a single convenient package. The adapter cable combines USB 3.0 and eSATA cables into an integrated cable, with no external power source or driver installation required, for simple and hassle-free installation - No assembly or searching for the right cable required.
With support for SuperSpeed USB 3.0 connectivity at transfer rates up to 5 Gbps (10 times faster than USB 2.0), and backward compatibility with USB 2.0, the USB 3.0 to eSATA adapter cable provides a fast and easy-to-use Plug-and-Play experience for home, office or laptop users alike.
StarTech.com SuperSpeed USB 3.0 to eSATA Cable Adapter - storage controller - eSATA 3Gb/s - USB 3.0
Storage controller - external
Bus Type
USB 3.0
eSATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Max Storage Devices Qty
1
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7, Apple MacOS X 10.2.x - 10.6.x
77 g
P/N: SATDOCK5U3ER
Host Bus
USB 3.0
Storage Controller
eSATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
1
1 x eSATA 3Gb/s - eSATA
1 x USB 3.0 - 9 pin USB Type A
1 x USB cable - external
FCC, RoHS
Limited warranty - 2 years , Technical support - lifetime
77 g
50 °C
5 - 85%
P/N: SATDOCK5U3ER
7P42 StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £28.42
