The USB3S2ESATA USB 3.0 to eSATA Adapter Cable lets you connect an external SATA (eSATA) device or enclosure to a host computer through USB 3.0, in a single convenient package. The adapter cable combines USB 3.0 and eSATA cables into an integrated cable, with no external power source or driver installation required, for simple and hassle-free installation - No assembly or searching for the right cable required.
With support for SuperSpeed USB 3.0 connectivity at transfer rates up to 5 Gbps (10 times faster than USB 2.0), and backward compatibility with USB 2.0, the USB 3.0 to eSATA adapter cable provides a fast and easy-to-use Plug-and-Play experience for home, office or laptop users alike.
- StarTech.com SuperSpeed USB 3.0 to eSATA Cable Adapter - storage controller - eSATA 3Gb/s - USB 3.0
- Storage controller - external
- Bus Type
- USB 3.0
- Interface
- eSATA 3Gb/s
- Data Transfer Rate
- 3 Gbit/s
- Supported Devices
- Hard drive
- Max Storage Devices Qty
- 1
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7, Apple MacOS X 10.2.x - 10.6.x
- 77 g
- 2-year warranty
- Designed For
- P/N: SATDOCK5U3ER
- Host Bus
- USB 3.0
Storage Controller
- Interface
- eSATA 3Gb/s
- 3 Gbit/s
- Supported Devices
- Hard drive
- 1
- 1 x eSATA 3Gb/s - eSATA
- Connections
- 1 x USB 3.0 - 9 pin USB Type A
- Cables Included
- 1 x USB cable - external
- FCC, RoHS
- OS Required
- Limited warranty - 2 years , Technical support - lifetime
- 77 g
- 0 °C
- 50 °C
- 5 - 85%
- Designed For
- P/N: SATDOCK5U3ER
