StarTech.com 3 ft Straight Through Serial Cable - DB9 M/F
Quicklinx: 8D56WS00 Mfr#: MXT1003
Length: 90cm
29 in stock
£3.30 ex VAT
£3.96 inc VAT
Extend the connection between your DB9 serial devices by up to 3 ft. The MXT1003 Serial Extension Cable features one DB9 male connector and one DB9 female connector, providing a high quality extension for your serial devices which enables you to position your peripheral devices as needed.
This DB9 extension cable is expertly designed and constructed of top quality materials to ensure durability.
StarTech.com 3 ft / 91cm Straight Through Serial Cable - DB9 Male to Female Serial Extension Cable 3ft (MXT1003) - serial extension cable - 90 cm
Serial extension cable
Length
90 cm
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
Grey
P/N: IC232TTL, ICUSB232D, ICUSB232IS, PEX2S953, PEX2S953LP, PEX4S953, PEX4S953LP
American Wire Gauge (AWG)
28
Length
90 cm
Grey
Connector
RoHS
8D56 StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.53
Length: 90cm
Price Range Ex VAT: 0 - 50
