StarTech.com 3 ft Slim High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable
Quicklinx: 7NYTWS00 Mfr#: HDMIMM3HSS
Length: 91cm
16 in stock
£6.74 ex VAT
£8.08 inc VAT
Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMIMM3HSS 3-foot Slim High Speed HDMI Cable supports advanced capabilities, including Ethernet data inter connectivity with compatible HDMI-capable devices, and features a thin cable design (3.5mm in diameter).
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI cables are expertly designed and constructed of only top quality materials to ensure high quality and high definition performance.
StarTech.com 3 ft Slim High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable M/M - 3ft Slim HDMI Cable - 3ft HDMI Cable (HDMIMM3HSS) - HDMI with Ethernet cable - 91 cm
Cable
American Wire Gauge (AWG)
36
Length
91 cm
Connector
HDMI - male
Connector (Second End)
HDMI - male
P/N: SV431DHD4KU, SV431HDU3A2
Cable Type
36
Jacket Material
PVC
Length
91 cm
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
7NYT StarTech.com 10 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable In Stock £8.94
7NYT StarTech.com 15 ft High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable In Stock £16.58
7NYT StarTech.com 20 ft High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable In Stock £32.75
7NYT StarTech.com 6 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable In Stock £6.94
7NYT StarTech.com 6 ft High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable HDMI to HDMI M/M In Stock £7.82
Length: 91cm
Price Range Ex VAT: 0 - 50
