StarTech.com 3 ft Slim High Speed HDMI Cable with Ethernet - HDMI to HDMI Mini M/M
Quicklinx: 7Q3TWS00 Mfr#: HDMIACMM3S
Type: HDMI
Length: 91cm
14 in stock
£7.37 ex VAT
£8.84 inc VAT
Connect HDMI Mini-equipped devices to displays incorporating HDMI technology, with minimal clutter, maximum quality and Ethernet Data Channel Support. The HDMIACMM3S 3-foot Slim High Speed HDMI to HDMI Mini cable supports advanced capabilities including Ethernet data interconnectivity with compatible HDMI-enabled devices, and features a thin cable design (3.5mm in diameter) suitable for installations with tight space requirements.
This High Speed HDMI to HDMI Mini cable lets you connect devices with an HDMI Mini (type C) port to a display/device with an HDMI (type A) port - a cost-saving solution for connecting cutting-edge and next-generation HDMI-capable devices to existing HDMI technology.
The HDMI/HDMI Mini cable features high quality gold-tipped connectors that ensure peak connectivity.
StarTech.com 3 ft Slim High Speed HDMI to Mini HDMI Cable with Ethernet - HDMI with Ethernet cable - 91 cm
Cable
American Wire Gauge (AWG)
36
TMDS Links
Single link
Length
91 cm
Connector
HDMI - male
Connector (Second End)
Mini HDMI - male
Cable Type
36
TMDS Links
Single link
Jacket Material
PVC
Length
91 cm
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
19 pin mini HDMI Type C - male
RoHS
Limited warranty - lifetime
7Q3T StarTech.com 6 ft High Speed HDMI Cable with Ethernet- HDMI to HDMI Mini- M/M In Stock £6.98
7Q3T StarTech.com 6 ft Slim High Speed HDMI Cable with Ethernet - HDMI to HDMI Mini M/M In Stock £7.95
7Q3T StarTech.com 3 ft Slim High Speed HDMI Cable with Ethernet - HDMI to HDMI Mini M/M In Stock £7.37
Type: HDMI
Length: 91cm
Price Range Ex VAT: 0 - 50
