Panel-mount a USB-B port, for easy access. The USBPNLBFBM3 3ft Panel Mount USB Cable features one USB-B male connector on one end and a USB-B panel mount female port on the other, providing a convenient solution for custom enclosures (e.g. internally mounted hard drives).
Offering 3ft in cable length, the adapter allows you to extend the connection as needed within the system case.
- StarTech.com 3 ft Panel Mount USB Cable B to B - F/M - USB cable - 90 cm
- USB cable
- Technology
- Shielded
- Molded
- Length
- 90 cm
- Connector
- 4 pin USB Type B - male
- Connector (Second End)
- 4 pin USB Type B - female
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 24/28
- Plated Connector
- Nickel
- Molded
- Length
- 90 cm
- Black
- Connector
- USB / USB 2.0, RoHS
