StarTech.com 3 ft Panel Mount USB Cable B to B - F/M
Quicklinx: 92Q8WS00 Mfr#: USBPNLBFBM3
Length: 90cm
More than 50 in stock
£4.59 ex VAT
£5.50 inc VAT
Panel-mount a USB-B port, for easy access. The USBPNLBFBM3 3ft Panel Mount USB Cable features one USB-B male connector on one end and a USB-B panel mount female port on the other, providing a convenient solution for custom enclosures (e.g. internally mounted hard drives).
Offering 3ft in cable length, the adapter allows you to extend the connection as needed within the system case.
StarTech.com 3 ft Panel Mount USB Cable B to B - F/M - USB cable - 90 cm
USB cable
Shielded
Molded
Length
90 cm
Connector
4 pin USB Type B - male
Connector (Second End)
4 pin USB Type B - female
USB / USB 2.0
USB cable
Shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Molded
Length
90 cm
Connector
USB / USB 2.0, RoHS
Length: 90cm
Price Range Ex VAT: 0 - 50
