StarTech.com 3 ft Panel Mount USB Cable A to A - F/M
Quicklinx: 93FMWS00 Mfr#: USBPNLAFAM3
Length: 91.4cm
More than 50 in stock
£4.59 ex VAT
£5.50 inc VAT
Add an external panel mount USB connection to a PC or faceplate. The USBPNLAFAM3 3ft Panel Mount USB Cable provides a well-secured, easy to access USB-A port on your PC or on a faceplate, allowing you to customize your systems to suit your needs. Perfect for podiums, kiosks and other solutions where added access to USB devices is required.
The adapter features one male USB-A connector and one female panel mount USB-A port and gives you an extension of 3ft, enabling you to place the cable as needed within the system case.
StarTech.com 3 ft Panel Mount USB Cable A to A - F/M - USB extension cable - 91.4 cm
USB extension cable
Double shielded
Length
91.4 cm
Connector
4 pin USB Type A - female
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
USB extension cable
Double shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Length
91.4 cm
Connector
USB / USB 2.0, RoHS
93FM StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £4.21
93FM StarTech.com 3 ft Panel Mount USB Cable A to A - F/M In Stock £4.59
93FM StarTech.com 2 ft Panel Mount USB Cable A to A - F/M In Stock £4.37
Length: 91.4cm
Price Range Ex VAT: 0 - 50
