This high quality USB 2.0 cable (A to Mini B) provides one (4-pin) USB Type A male connector and one Mini B (5-pin) male connector, and can support data high speed USB 2.0 transfer rates of up to 480Mbps.
A high quality replacement for connecting your digital camera (Canon, Sony, Hewlett-Packard) to a host computer, this USB A to Mini B cable also delivers a cost-effective way to maximize the file transfer performance of your MP3 player, PDA, or digital camcorder.
Expertly designed and constructed of only top quality materials, the A to Mini B USB 2.0 cable provides pure digital data transfers for sharper, more natural images and sound at higher speeds.
- StarTech.com 3ft Mini USB 2.0 Cable - A to Mini B - M/M - USB cable - 91 cm
- USB cable
- Length
- 91 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- Mini-USB Type B - male
- USB / USB 2.0
- Limited lifetime warranty
- Designed For
- P/N: SAT1810U2, SLMSOPTB, PEXUSB7LP, UNI2510U2V, SAT2510U2F, SATCAS25OTGB, SATCAS35U2GB, SATCASE25OTG, SATCASE35U2, IDECASE25U2B
- USB cable
- Length
- 91 cm
- Connector
- USB / USB 2.0
- Designed For
- StarTech.com 1.8in USB to Micro SATA Hard Drive Enclosure, 2.5in Silver USB 2.0 One Button IDE External Hard Drive Enclosure, 2.5in Tool-less USB 2.0 to IDE SATA External Hard Drive Enclosure, 2.5in USB FireWire SATA External Hard Drive Enclosure, 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card, USB to Slimline SATA CD/DVD Optical Drive Enclosure , StarTech.com InfoSafe 2.5" SATA to USB 2.0 On-The-Go Drive Enclosure, 3.5" USB 2.0 to SATA Drive Enclosure
