StarTech.com 3 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - White
Quicklinx: 907MWS00 Mfr#: MDP2VGAMM3W
22 in stock
£19.27 ex VAT
£23.12 inc VAT
Connect a Mini DisplayPort-equipped PC or Mac to a nearby VGA monitor/projector, with a short 3ft white cable. The MDP2VGAMM3W active Mini DisplayPort to VGA converter cable lets you connect your Mini DisplayPort-equipped desktop or laptop directly to a nearby VGA monitor or projector, saving the expense of additional adapters while eliminating the clutter of excess cable. The converter features a stylish white design, that is well-suited for connecting Mac computers.
The adapter cable is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
StarTech.com 3ft Mini DisplayPort to VGA Adapter Cable mDP to VGA - White - video converter - white
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
Enclosure Colour
White
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - male
Active cable (signal regeneration), Thunderbolt port compatible
1 - 90 cm
FCC, RoHS, WEEE
78 g
Enclosure Colour
White
Limited warranty - 3 years
60 °C
40 - 85%
Price Range Ex VAT: 0 - 50
