StarTech.com 3 ft Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k
Quicklinx: 6PF5WS00 Mfr#: MDISPLPORT3
Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and monitor. The MDISPLPORT3 3ft Mini DisplayPort 1.2 cable features 2 Mini DP male connectors, and offers a dependable solution for connecting any Mini DisplayPort-enabled laptop (including Mac family of products) to a Mini DisplayPort-equipped monitor.
The mDP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DisplayPort Cables can be connected to the Thunderbolt ports, enabling you to connect your Mini DP compatible displays.
StarTech.com 3 ft Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k with HBR2 support - 3 feet Mini DP to Mini DP 1.2 Cable (MDISPLPORT3) - DisplayPort cable - 91 cm
DisplayPort cable
Length
91 cm
Connector
Mini DisplayPort - male
Connector (Second End)
RoHS
P/N: BOX4HDECP, CDP2HDMDP, CDP2MDP, CDP2MDPEC, CDP2MDPFC, CDP2MDPVGA, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP, DP2MDPMF3, DP2MDPMF6IN, MDPEXT3, MDPEXT6
DisplayPort cable
American Wire Gauge (AWG)
36
Plated Connector
Nickel
Length
91 cm
Connector
RoHS
6PF5 StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.12
6PF5 StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £11.28
6PF5 StarTech.com Mini DisplayPort to VGA Video Adapter Converter In Stock £16.89
6PF5 StarTech.com Mini DisplayPort to HDMI Video Adapter Converter In Stock £11.67
6PF5 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.12
6PF5 StarTech.com 1m Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £13.69
6PF5 StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £14.48
6PF5 StarTech.com 2m (6 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £16.38
6PF5 StarTech.com 3m (10 ft) White Mini DisplayPort Cable - M/M In Stock £17.45
