StarTech.com 3 ft Micro USB Cable - A to Right Angle Micro B
Quicklinx: 76RBWS00 Mfr#: UUSBHAUB3RA
Length: 90cm
13 in stock
£3.87 ex VAT
£4.64 inc VAT
Charge or sync your Micro-B USB devices with the cable out of the way. The UUSBHAUB3RA 3-foot USB-A to Micro-B Cable provides a high quality connection between Micro USB-equipped USB 2.0 mobile devices (such as BlackBerry or Android-based smart phones, digital cameras, PDAs, Tablet PC devices and GPS systems, etc.) and a USB-capable computer, for everyday tasks such as data synchronization, file transfers and charging.
The right-angled Micro USB connector positions the cable in such a way that it allows you to easily access your mobile digital device in both portrait and landscape mode, even while charging.
As an alternative, StarTech.com also offers a 3ft USB A to Left Angle Micro B Cable (UUSBHAUB3LA), which provides the same convenience as this right-angled cable but allows you to connect to your USB Micro-B devices from the opposite direction.
StarTech.com 3 ft Micro USB Cable - A to Right Angle Micro B - USB cable - 90 cm
USB cable
90° connector
Length
90 cm
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - male
P/N: PEXUSB7LP
USB cable
90° connector
Length
90 cm
Connector
RoHS
StarTech.com 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card
76RB StarTech.com 3ft Micro USB Cable - A to Micro B In Stock £3.79
76RB StarTech.com 3 ft Micro USB Cable - A to Right Angle Micro B In Stock £3.87
76RB StarTech.com 1ft Micro USB Cable - A to Micro B In Stock £3.68
76RB StarTech.com 1 ft Micro USB Cable - A to Left Angle Micro B In Stock £1.87
76RB StarTech.com 1 ft Micro USB Cable - A to Right Angle Micro B In Stock £3.76
76RB StarTech.com 6in Micro USB Cable - A to Micro B In Stock £3.42
76RB StarTech.com 6 ft Micro USB Cable A to Right Angle Micro B In Stock £4.78
76RB StarTech.com 0.5m Angled Micro USB Cable In Stock £3.87
Length: 90cm
Price Range Ex VAT: 0 - 50
