Product
StarTech.com 3 ft Micro USB Cable - A to Left Angle Micro B
Quicklinx: 7B88WS00 Mfr#: UUSBHAUB3LA
Length: 91cm
More than 50 in stock
£3.87 ex VAT
£4.64 inc VAT
Charge or sync your Micro-B USB devices with the cable out of the way. The UUSBHAUB3LA 3-foot USB-A to Micro-B Cable provides a high quality connection between Micro USB-equipped USB 2.0 mobile devices (such as BlackBerry or Android-based smart phones, digital cameras, PDAs, Tablet PC devices and GPS systems, etc.) and a USB-capable computer, for everyday tasks such as data synchronization, file transfers and charging.
The left-angled Micro USB connector positions the cable in such a way that it allows you to easily access your mobile digital device in both portrait and landscape mode, even while charging.
As an alternative, StarTech.com also offers a UUSBHAUB3RA 3ft USB A to Right Angle Micro B Cable, which provides the same convenience as this left-angled cable but allows you to connect to your USB Micro-B devices from the opposite direction.
StarTech.com 3 ft Micro USB Cable - A to Left Angle Micro B - USB cable - 91 cm
USB cable
90° connector, left-angled connector
Length
91 cm
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - male
USB / USB 2.0
USB cable
American Wire Gauge (AWG)
30
Length
91 cm
Connector
USB / USB 2.0, RoHS
Length: 91cm
Price Range Ex VAT: 0 - 50
