StarTech.com 3 ft Micro USB Cable - A to Left Angle Micro B
Quicklinx: 7B88WS00 Mfr#: UUSBHAUB3LA
Length: 91cm
£3.88 ex VAT
£4.65 inc VAT
Charge or sync your Micro-B USB devices with the cable out of the way. The UUSBHAUB3LA 3-foot USB-A to Micro-B Cable provides a high quality connection between Micro USB-equipped USB 2.0 mobile devices (such as BlackBerry or Android-based smart phones, digital cameras, PDAs, Tablet PC devices and GPS systems, etc.) and a USB-capable computer, for everyday tasks such as data synchronization, file transfers and charging.
The left-angled Micro USB connector positions the cable in such a way that it allows you to easily access your mobile digital device in both portrait and landscape mode, even while charging.
As an alternative, StarTech.com also offers a UUSBHAUB3RA 3ft USB A to Right Angle Micro B Cable, which provides the same convenience as this left-angled cable but allows you to connect to your USB Micro-B devices from the opposite direction.
StarTech.com 3 ft / 91cm Micro USB Cable - A to Left Angle Micro B - USB Type A - 90 Degree Micro-USB Type B (M) - Black (UUSBHAUB3LA) - USB cable - 91 cm
USB cable
Molded, sync and charge
Length
91 cm
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - male - 90° left-angled
USB / USB 2.0
P/N: ST4200MINI2, USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB
USB cable
Jacket Material
PVC
American Wire Gauge (AWG)
30
Length
91 cm
19 g
Connector
USB / USB 2.0, RoHS
Shipping Weight
24 g
7B88 StarTech.com 3ft Micro USB Cable - A to Micro B In Stock £3.86
7B88 StarTech.com 1ft Micro USB Cable - A to Micro B In Stock £3.70
7B88 StarTech.com 1 ft Micro USB Cable - A to Left Angle Micro B In Stock £1.87
7B88 StarTech.com 1 ft Micro USB Cable - A to Right Angle Micro B In Stock £3.76
7B88 StarTech.com 6in Micro USB Cable - A to Micro B In Stock £3.43
7B88 StarTech.com 6 ft Micro USB Cable A to Left Angle Micro B In Stock £4.81
7B88 StarTech.com 0.5m Angled Micro USB Cable In Stock £3.88
Length: 91cm
Price Range Ex VAT: 0 - 50
