StarTech.com 3 ft mDP to HDMI cable - 4K
Quicklinx: B90QWS00 Mfr#: MDP2HDMM1MW
12 in stock
£13.14 ex VAT
£15.76 inc VAT
Eliminate clutter by connecting your Mac or PC directly to an HDMI display using this short cable. This 3-foot Mini DisplayPort to HDMI adapter cable offers a single-cable connection from your mDP equipped MacBook or Ultrabook laptop to an HDMI display or projector. The passive adapter supports video resolutions up to Ultra HD 4K and is Thunderbolt compatible when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
This adapter cable ensures you can maintain an astonishing picture quality, four times the resolution of 1080p, when converting Mini DisplayPort to HDMI.
The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
For the simplest and most discreet installation, this mDP to HDMI adapter connects directly from your Mini DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate video cabling.
At 3ft in length, this adapter cable delivers a compact connection that eliminates excess to ensure a tidy, professional installation. For longer installations, StarTech.com also offers a 6 ft mDP to HDMI cable (MDP2HDMM2MW) enabling you to choose the right cable length for your custom installation needs.
The MDP2HDMM1MWis a stylish white adapter that looks great next to your Mac computer.
StarTech.com Mini DisplayPort to HDMI Converter Cable - 3 ft (1m) - mDP to HDMI Adapter with Built-in Cable - (M / M) Ultra HD 4K - White (MDP2HDMM1MW) - video cable - DisplayPort / HDMI - 1 m
Cable
Video cable - DisplayPort / HDMI
Length
1 m
White
Connector
Mini DisplayPort - male
Connector (Second End)
HDMI - male
DisplayPort 1.2
4K support
3-year warranty
Cable Type
Video cable - 4K support
Interface Supported
DisplayPort / HDMI
DisplayPort 1.2
Length
1 m
HDCP compliant, DPCP compliant
White
Connector
19 pin HDMI Type A - male
FCC, RoHS
Limited warranty - 3 years
B90Q StarTech.com 3ft DP to HDMI cable - 4K In Stock £16.40
B90Q StarTech.com 3 ft mDP to HDMI cable - 4K In Stock £13.14
B90Q StarTech.com 6ft mDP to HDMI cable - 4K In Stock £14.09
B90Q StarTech.com 6 ft DP to HDMI cable - 4K In Stock £17.03
B90Q StarTech.com 3ft mDP to HDMI cable - 4K In Stock £14.12
Price Range Ex VAT: 0 - 50
