Connect an HDMI Micro-equipped Smartphone or Portable Device to your HDMI-capable TV or Display. The HDMIADMM3 3-foot High Speed HDMI to HDMI Micro cable lets you connect devices with a HDMI Micro port to a display/device with a standard HDMI port - a cost-saving solution for connecting cutting-edge and next-generation HDMI-capable devices to existing HDMI technology.
The HDMI/HDMI Micro cable features high-quality gold-tipped connectors that ensure peak connectivity.
- StarTech.com 3 ft High Speed HDMI? Cable with Ethernet - HDMI to HDMI Micro - M/M (HDMIADMM3) - HDMI with Ethernet cable - 91 cm
- Cable
- American Wire Gauge (AWG)
- 34
- Length
- 91 cm
- Black
- Connector
- HDMI - male
- Connector (Second End)
- Micro HDMI - male
- Limited lifetime warranty
- Cable Type
- 34
- Jacket Material
- PVC
- Length
- 91 cm
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- 19 pin micro HDMI Type D - male
- RoHS
- Limited warranty - lifetime
StarTech.com 6 ft High Speed HDMI Cable with Ethernet- HDMI to HDMI Mini- M/M | In Stock | £8.12 |
StarTech.com 6in High Speed HDMI Port Saver Cable M/F - Ultra HD 4k x 2k HDMI Cable | In Stock | £10.37 |
StarTech.com 3 ft High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M | In Stock | £8.94 |
StarTech.com HDMI Coupler / Gender Changer - F/F | In Stock | £7.22 |
