Connect a VGA output (video card, etc.) to a display/monitor that uses Component video input. The HD15CPNTMM3 3ft HD15 to Component RCA Breakout Cable Adapter features a male VGA (HD15) connector and male component video connectors, allowing you to connect a VGA output (video card, etc.) to a display/monitor that uses Component video input.
This cable requires a video converter or output device that can process a YPbPr signal through an HD15 (VGA) port.
- StarTech.com 3 ft. (0.9 m) VGA to RCA Cable - RCA Breakout - HD15 (M)/Component (M) - VGA to Component (HD15CPNTMM3) - VGA cable - 91 cm
- VGA cable
- Length
- 91 cm
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- 3 x RCA - male
- RoHS
- Limited lifetime warranty
- Designed For
- P/N: DVI2VGA, VGA2HD2, VID2VGATV, VID2VGATV2, VID2VGATV3
- VGA cable
- Length
- 91 cm
- Connector
- 15 pin HD D-Sub (HD-15) - male
- 3 x RCA - male
- RoHS
- Designed For
