Connect power eSATA devices to the eSATA and USB ports on your computer. This eSATA and USB A Male to Power eSATA Cable provides a 3 ft connection between an external drive enclosure equipped with a power eSATA port and the eSATA and USB port on a PC/notebook, providing both power (through USB) and data (through SATA) using a single cable.
The 3 ft eSATA and USB A Male to Power eSATA Male cable is expertly designed and constructed of only top quality materials.
- StarTech.com eSATA and USB A to Power eSATA Cable - Power Over eSATA cable - 91 cm
- Length
- 91 cm
- Connectors
- 11 pin USB/eSATA - male
- Connectors (Second End)
- 7 pin external Serial ATA - male , 4 pin USB Type A - male
- Limited lifetime warranty
- Designed For
- P/N: S251SMU33EP
- Storage Cable Type
- Length
- 91 cm
- Connectors
- Designed For
- P/N: S251SMU33EP
