Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort monitor and a DisplayPort source. The DP2MDPMF3 3ft DisplayPort to Mini DisplayPort 1.2 Cable Adapter turns a Mini DP male connector into a regular DisplayPort male connector, making it easy to connect a Mini DisplayPort-equipped monitor to a laptop that only provides a standard DisplayPort output (e.g. Toshiba etc.).
The DP to Mini DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
- StarTech.com 3 ft DisplayPort to Mini DisplayPort 1.2 Video Cable Adapter M/F - DisplayPort 4k with HBR2 support - DP (M) to Mini DP (F) (DP2MDPMF3) - DisplayPort adapter - 90 cm
- Molded
- Length
- 90 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- Mini DisplayPort - female
- RoHS, NEC-CMG
- Limited lifetime warranty
- American Wire Gauge (AWG)
- 32
- Plated Connector
- Nickel
- Molded
- Length
- 90 cm
- Connector
- 20 pin DisplayPort - male
- DisplayPort 1.2, RoHS, NEC-CMG
