StarTech.com 3 ft DisplayPort to Mini DisplayPort 1.2 Video Cable Adapter M/F - DisplayPort 4k
Quicklinx: 7ZMFWS00 Mfr#: DP2MDPMF3
Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort monitor and a DisplayPort source. The DP2MDPMF3 3ft DisplayPort to Mini DisplayPort 1.2 Cable Adapter turns a Mini DP male connector into a regular DisplayPort male connector, making it easy to connect a Mini DisplayPort-equipped monitor to a laptop that only provides a standard DisplayPort output (e.g. Toshiba etc.).
The DP to Mini DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
StarTech.com 3 ft DisplayPort to Mini DisplayPort 1.2 Video Cable Adapter M/F - DisplayPort 4k with HBR2 support - DP (M) to Mini DP (F) (DP2MDPMF3) - DisplayPort adapter - 90 cm
DisplayPort adapter
Molded
Length
90 cm
Connector
DisplayPort - male
Connector (Second End)
Mini DisplayPort - female
RoHS, NEC-CMG
DisplayPort adapter
American Wire Gauge (AWG)
32
Plated Connector
Nickel
Molded
Length
90 cm
Connector
20 pin DisplayPort - male
DisplayPort 1.2, RoHS, NEC-CMG
7ZMF StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.84
7ZMF StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £31.28
7ZMF StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £23.82
7ZMF StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.12
7ZMF StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £11.28
7ZMF StarTech.com Mini DisplayPort to VGA Video Adapter Converter In Stock £16.89
7ZMF StarTech.com Mini DisplayPort to HDMI Video Adapter Converter In Stock £11.67
7ZMF StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.86
7ZMF StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £15.72
