StarTech.com 3 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
Quicklinx: 6PF4WS00 Mfr#: DISPLPORT3L
Type: DisplayPort
Length: 91cm
More than 50 in stock
£9.72 ex VAT
£11.66 inc VAT
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort -equipped devices. The DISPLPORT3L 3ft DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
StarTech.com 3 ft DisplayPort 1.2 Cable with Latches M/M - DisplayPort 4k - DisplayPort cable - 91 cm
DisplayPort cable
Shielded
Latched
Length
91 cm
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
P/N: BOX4HDECP2, CDP2DP, CDP2DP14B, CDP2DPUCP, CDP2DPW, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DKWG30DPHPD, DKWG30DPHPDU, DVI2DP2, HD2DPVGADVI, MOD4AVHD, MOD4AVHDBT, MST14DP123DP, SV211DPUA4K, SV231DPDDUA2, SV231DPU34K, SV431DPDDUA2, SV431DPUA2, TB32DP2T, USB32DP24K60, USB32DPES2
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
30
Plated Connector
Nickel
Latched
Length
91 cm
Connector
20 pin DisplayPort - male
RoHS
P/N: BOX4HDECP2, CDP2DP, CDP2DP14B, CDP2DPUCP, CDP2DPW, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DKWG30DPHPD, DKWG30DPHPDU, DVI2DP2, GCMDP2DPMF, HD2DP, HD2DPVGADVI, HDMI2DP, HDVGADP2HD, MDP2DPDVHD, MDP2DPMF6IN, MOD4AVHD, MOD4AVHDBT, MST14DP123DP, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, SV211DPUA, SV211DPUA4K, SV231DPDDUA, SV231DPDDUA2, SV231DPU34K, SV431DPDDUA2, SV431DPU3A2, SV431DPUA, SV431DPUA2, TB32DP2, TB32DP2T, USB32DP24K60, USB32DP4K, USB32DPES2, USB32DPPRO, USB3DOCKHDPC, USB3VDOCK4DP
6PF4 StarTech.com 25 ft DisplayPort Cable with Latches - M/M In Stock £45.83
6PF4 StarTech.com 6 ft DisplayPort Video Extension Cable - M/F In Stock £22.42
6PF4 StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £11.16
6PF4 StarTech.com 3 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £9.72
6PF4 StarTech.com 1 ft Short DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £10.20
6PF4 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.69
Type: DisplayPort
Length: 91cm
Price Range Ex VAT: 0 - 50
