StarTech.com 3 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
Quicklinx: 6PF4WS00 Mfr#: DISPLPORT3L
Type: DisplayPort
Length: 91cm
More than 50 in stock
£9.72 ex VAT
£11.66 inc VAT
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort -equipped devices. The DISPLPORT3L 3ft DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
StarTech.com 3 ft DisplayPort 1.2 Cable with Latches M/M - DisplayPort 4k - DisplayPort cable - 91 cm
DisplayPort cable
Shielded
Latched
Length
91 cm
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
P/N: USB32DPPRO
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
30
Plated Connector
Nickel
Latched
Length
91 cm
Connector
20 pin DisplayPort - male
RoHS
P/N: USB32DPPRO
6PF4 StarTech.com 6 ft DisplayPort Video Extension Cable - M/F In Stock £22.18
6PF4 StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £11.08
6PF4 StarTech.com 3 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £9.72
Type: DisplayPort
Length: 91cm
Price Range Ex VAT: 0 - 50
