StarTech.com provides you with 3-ft., 9 pin Male to Female Modem Cables with lifetime warranties in case the impossible happens. StarTech.com's cables are made with components of the highest quality.
- StarTech.com - serial cable - DB-9 to DB-9 - 92 cm
- Serial cable
- Length
- 92 cm
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - female
- Limited lifetime warranty
- Serial cable
- Length
- 92 cm
- Connector
