Your basket is empty
StarTech.com 3 ft DB9 Serial Modem Cable - M/F
Quicklinx: 8CNPWS00 Mfr#: MC93MF
StarTech.com provides you with 3-ft., 9 pin Male to Female Modem Cables with lifetime warranties in case the impossible happens. StarTech.com's cables are made with components of the highest quality.
StarTech.com serial cable - 92 cm
Serial cable
Length
92 cm
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
Serial cable
Length
92 cm
Connector
