StarTech.com 3 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F
Quicklinx: 6BB4WS00 Mfr#: MXT101HQ3
This 3ft High Resolution VGA Extension Cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male to female coaxial VGA extension cable helps to eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 3 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F - 3ft VGA Extension Cable (MXT101HQ3) - VGA extension cable - 0.9 m
VGA extension cable
Coaxial
Molded, ferrite bead
Length
0.9 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
FCC
P/N: DP2VGAMM6, DP2VGAMM6B, HD2VGAMM6, MXT101MM, SV231USBLC, SV431USB, SVUSB2N1_6, VGABNCMF1
VGA extension cable
Coaxial
Length
0.9 m
Connector
15 pin HD D-Sub (HD-15) - female
FCC
