StarTech.com 3 ft Angled Lightning Cable
Quicklinx: BNPQWS00 Mfr#: USBLT1MWR
Length: 1m
Colours:
Hurry, only 3 left in stock!
£13.13 ex VAT
£15.75 inc VAT
Charge or sync your iPhone, iPod or iPad with the cable out of the way. This right-angled Lightning­ cable is great for charging your Apple mobile devices in a car, or for accessing your phone or tablet while it's connected to a wall charger or computer.
The cable features a right-angled Lightning connector that lets you connect to ports that are difficult to reach, which is perfect for charging your car-mounted mobile devices. Even while you're charging your mobile device, you can use it to text, work or game, without the cable getting in the way.
The angled connector also prevents the cable from bending awkwardly or from straining too much to make a connection. It offers a more natural fit at the connection point, preventing unnecessary stress and damage to the cable and device port.
Replace the Lightning cable that came with your mobile device, or keep one as a spare while traveling so that your mobile devices will be ready to use while you're on the road.
StarTech.com 1m 3 ft Angled Lightning to USB Cable - White - Lightning cable - Lightning / USB - 1 m
Cable
American Wire Gauge (AWG)
24/28
Length
1 m
White
Connector
Lightning - male
Connector (Second End)
USB - male
Angled connector
Apple 12.9-inch iPad Pro (1st generation, 2nd generation); iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus; iPod nano (7G); iPod touch (5G, 6G)
Cable Type
Lightning cable - angled connector
Interface Supported
Lightning / USB
24/28
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Lightning - male
4 pin USB Type A - male
Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus , Apple iPod nano (7G) , Apple iPod touch (5G, 6G)
Length: 1m
Price Range Ex VAT: 0 - 50
