StarTech.com 3 ft A Right Angle to B Right Angle USB Cable - M/M
Quicklinx: 76R7WS00 Mfr#: USB2HAB2RA3
Length: 91cm
More than 50 in stock
£4.13 ex VAT
£4.95 inc VAT
Connect USB 2.0 peripherals to your computer, for installation in narrow spaces. The USB2HAB2RA3 3ft USB A-to-B cable features a right angle USB ''A'' male connector and a right angle USB ''B'' male connector, for high quality connections to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives, even in hard to reach areas and narrow spaces.
The right-angled USB connectors position the cable nearly flush against a wall or other surface, and eliminate the space typically required to accommodate a ''straight'' connection from the cable into the USB port or peripheral device.
StarTech.com 3 ft / 91cm A Right Angle to B Right Angle USB Cable - 0.91m Right Angle USB 2.0 - 1x USB A 1x USB B - Black (USB2HAB2RA3) - USB cable - 91 cm
USB cable
Shielded twisted pair (STP)
90° connector, molded
Length
91 cm
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type B - male
USB / USB 2.0
P/N: ICUSB23208FD, ICUSB23216FD, ICUSB232D
USB cable
American Wire Gauge (AWG)
24/28
Length
91 cm
Connector
USB / USB 2.0, RoHS
76R7 StarTech.com 15 ft USB 2.0 A to B Cable - M/M In Stock £4.36
76R7 StarTech.com 10 ft Transparent USB 2.0 Cable - A to B In Stock £1.89
76R7 StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.83
76R7 StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.16
76R7 StarTech.com 6 ft Transparent USB 2.0 Cable - A to B In Stock £3.64
76R7 StarTech.com 3 ft A Right Angle to B Right Angle USB Cable - M/M In Stock £4.13
Length: 91cm
Price Range Ex VAT: 0 - 50
