Connect USB 2.0 peripherals to your computer, for installation in narrow spaces. The USB2HAB2RA3 3ft USB A-to-B cable features a right angle USB ''A'' male connector and a right angle USB ''B'' male connector, for high quality connections to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives, even in hard to reach areas and narrow spaces.
The right-angled USB connectors position the cable nearly flush against a wall or other surface, and eliminate the space typically required to accommodate a ''straight'' connection from the cable into the USB port or peripheral device.
- StarTech.com 3 ft A Right Angle to B Right Angle USB Cable - M/M - USB cable - 91 cm
- USB cable
- Technology
- Shielded twisted pair (STP)
- 90° connector, molded
- Length
- 91 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- American Wire Gauge (AWG)
- 24/28
- Length
- 91 cm
- Black
- Connector
- USB / USB 2.0, RoHS
