Product
StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F
Quicklinx: 76RLWS00 Mfr#: DPPNLFM3PW
Type: DisplayPort
Length: 91cm
13 in stock
£13.08 ex VAT
£15.69 inc VAT
The DPPNLFM3PW 3ft DisplayPort Extension Panel Mount Cable features one DP male connector and one panel mount DP female connector, providing a well-secured, easy to access DisplayPort connection on your PC or faceplate, and allowing you to customize your systems to suit your needs. If power is required, the DisplayPort Cable uses all 20 pins and can deliver power accordingly.
StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F - DisplayPort cable - 91 cm
DisplayPort cable
Latched, molded, integrated power connectors
Length
91 cm
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - female
RoHS, NEC-CMG
DisplayPort cable
American Wire Gauge (AWG)
28
Length
91 cm
Connector
20 pin DisplayPort - male
20 pin DisplayPort - female
RoHS, NEC-CMG
76RL StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £15.23
76RL StarTech.com 6 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £11.08
76RL StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.85
76RL StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £10.93
76RL StarTech.com 25 ft DisplayPort Cable with Latches - M/M In Stock £45.83
76RL StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £33.00
76RL StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £26.71
76RL StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £22.13
76RL StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.69
Type: DisplayPort
Length: 91cm
Price Range Ex VAT: 0 - 50
