StarTech.com 3 ft 1s1p USB to Serial Parallel Port Adapter Cable
Quicklinx: 7Y3GWS00 Mfr#: ICUSB2321284
£19.58 ex VAT
£23.49 inc VAT
Add one RS232 Serial, and one IEEE 1284 Parallel port to your computer through a single USB connection. The ICUSB2321284 1S1P USB to Serial/Parallel Adapter Cable enables you to connect DB9 RS232 serial devices and IEEE 1284 parallel devices to your PC or Linux laptop or desktop computer, through a single USB port, as though the computer offered onboard connectors. An innovative solution, the adapter cable features both a parallel and serial port that can be used simultaneously, delivering serial and parallel data rates of up to 921.6 Kbps and 1Mbps (respectively) to ensure optimum performance from your connected devices. Simple to install and use, the serial/parallel USB adapter is a cost-effective solution that bridges the connectivity gap between modern computers and legacy serial peripherals.
StarTech.com 1s1p USB to Serial Parallel Port Adapter Cable - parallel/serial adapter
Parallel/serial adapter
External
Interface (Bus) Type
USB
72 g
Parallel, RS-232
Data Transfer Rate
921.6 Kbps
MosChip Semiconductor
USB 1.1
Linux, Microsoft Windows CE 5.0, Microsoft Windows Vista / XP / 7, Windows 10 (32/64 bits)
3-year warranty
External
USB
Wired
Parallel, RS-232
Data Transfer Rate
921.6 Kbps
USB powered
USB 1.1
Processor / Memory
1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) , 1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB - 4 pin USB Type A
1 x USB cable (integrated) - 92 cm
RoHS
72 g
Limited warranty - 3 years
60 °C
7Y3G StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
7Y3G StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
7Y3G StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
7Y3G StarTech.com 16 ft USB 2.0 Active Extension Cable - M/F In Stock £13.61
7Y3G StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.18
Price Range Ex VAT: 0 - 50
