StarTech.com 3 ft 14AWG Computer Power Cord Extension - C14 to C13 Power Cable
Quicklinx: 8G59WS00 Mfr#: PXT100143
Select:
  • 1m
Extend the power connection from your server to a PDU by up to 3ft. The PXT100143 C13 to C14 PDU Style Computer Power Extension Cord (3ft) features 14 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher rated, heavier gauge cable, and connecting to Power Distribution Units (PDU).
This PDU style extension cord/cable is designed and constructed for maximum durability.
StarTech.com 3ft (1m) Heavy Duty Extension Cord, IEC C14 to IEC C13 Black Extension Cord, 15A 125V, 14AWG, Heavy Gauge Power Extension Cable, IEC C14 to IEC C13 AC Power Cord - UL Listed - power extension cable - IEC 60320 C14 to power IEC 60320 C13 - 90 cm
Power extension cable
Length
90 cm
Connector
Power IEC 60320 C14
Connector (Second End)
Power IEC 60320 C13
Rated Voltage
AC 250 V
American Wire Gauge (AWG)
14
Rated Voltage
AC 250 V
Length
90 cm
Connector
Power IEC 60320 C14
Power IEC 60320 C13
UL, RoHS
