Easily connect and hot swap up to three 3.5" SATA/SAS hard drives from two 5.25" bays. The HSB3SATSASBA Removable 3-drive backplane lets you quickly install and hot-swap 3.5" drives from the front of your computer, by turning two 5.25" bays into a hot-swappable interface for you to connect up to three 3.5" SATA or SAS hard drives (HDD).
For added versatility, the hard drive bay can interface with SATA I/II/III and SAS I/II hard drives - an ideal accommodation for enterprise system applications.
For a quick and secure method of installing and removing drives, the backplane features ejection levers and a key-lock design. To help prevent drive failure, the bay provides excellent heat dissipation with a built-in fan, and a vented solid aluminum enclosure.
- StarTech.com 3-Bay Hot Swap Backplane for 3.5in SAS II/SATA III - 6 Gbps HDD - Aluminum Trayless Mobile Rack Backplane (HSB3SATSASBA) - storage mobile rack
- Storage mobile rack
- Black
- Expansion Bays
- 3 x hot-swap - 3.5"
- Compatible Bay
- 2 5.25"
- Hard Drive Form Factor Compatibility
- 2.5"
- Supported Interface
- SATA-600
- Drive Connector
- 29 pin internal SAS (SFF-8482)
- Data indicator, power indicator
- Product Material
- Aluminium
- 14.5 cm x 19.41 cm x 11 cm
- 1.2 kg
- 2-year warranty
- Designed For
- P/N: 25SAT35HDD, PEXMSATA3422, PEXMSATA343
- 2.5"
- Product Material
- Aluminium
- Black
- SATA-600
Storage Controller
- Processor
- No CPU
- Bays
- 3 x SATA 6Gb/s - 29 pin internal SAS (SFF-8482)
- Connections
- 3 - 7 pin Serial ATA , 2 - 15 pin Serial ATA power
- Compatible Bay
- 2 x external 5.25"
- Cables Included
- 3 x Serial ATA cable - 45.72 cm
- Mounting Kit
- Included
- FCC, RoHS
- Limited warranty - 2 years
- 14.5 cm
- 19.41 cm
- 11 cm
- 1.2 kg
- 0 °C
- 55 °C
- 5 - 85%
- Designed For
StarTech.com 12in Latching SATA Cable | In Stock | £3.34 |
StarTech.com 18in Latching SATA Cable | In Stock | £3.77 |
StarTech.com 24in Latching SATA Cable | In Stock | £4.50 |
StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive | In Stock | £14.75 |
StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane | In Stock | £36.57 |
StarTech.com 8in Latching SATA to SATA Cable - F/F | In Stock | £3.42 |
StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III | In Stock | £65.05 |
