Easily connect and swap two 2.5in SATA hard drives or SSDs through a single 3.5in front bay. The HSB225SATBK 3.5in SATA Mobile Rack lets you install two 2.5in SATA (SATA, SATA II, SATA III-6Gbps) hard drives (HDD) or solid state drives (SSD) into an available/unused 3.5in floppy drive bay.
The mobile rack delivers quick and easy access to hard drive contents, using a convenient "no mounting required/easy eject" feature which eliminates the need for the drives to be installed in a tray - a time-saving solution for instant drive removals and insertions, as part of a system building process or integration into rackmount systems or industrial environments.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
For added safety, the mobile rack is made from UL94 V-0 rated plastics and equipped with locking bay doors to help prevent accidental or unauthorized removal of the swappable hard drives. Also a perfect addition for operating system image deployment and any task that requires being able to access large volumes of data on the fly, the hot swap bay provides everything you need to expedite important projects while maintaining a reliable storage solution.
- StarTech.com 3.5in Trayless Hot Swap SATA Mobile Rack for Dual 2.5in Hard Drives - storage mobile rack
- Storage mobile rack
- Black
- Expansion Bays
- 2 x hot-swap - 2.5"
- Compatible Bay
- 2 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Supported Interface
- SATA 3 Gb/s
- Drive Connector
- 22 pin Serial ATA
- Data indicator, power indicator
- Product Material
- Plastic, steel
- 10.1 cm x 15.4 cm x 2.5 cm
- 224 g
- 2-year warranty
- Designed For
- P/N: PEXMSATA3422, PEXMSATA343, PEXSAT34RH
- 2.5"
- Product Material
- Plastic, steel
- Black
- SATA 3 Gb/s
Storage Controller
- Processor
- No CPU
- Bays
- 2 x SATA 3Gb/s - SATA combo
- Connections
- 2 storage - Serial ATA-300 - 7 pin Serial ATA , 1 storage - Serial ATA-300 - 22 pin Serial ATA
- Compatible Bay
- 2 x external 2.5"
- Cables Included
- 2 x Serial ATA cable
- Mounting Kit
- Included
- Plug and Play, FCC, RoHS, UL 94 V-0
- Limited warranty - 2 years
- 10.1 cm
- 15.4 cm
- 2.5 cm
- 224 g
- 5 °C
- 70 °C
- 8 - 90%
- Designed For
StarTech.com 24" Serial ATA Cable | In Stock | £5.18 |
StarTech.com 18in SATA Serial ATA Data and Power Combo Cable | In Stock | £6.44 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £4.34 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.16 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.58 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £12.60 |
