StarTech.com 3.5in Silver USB 3.0 External SATA III Hard Drive Enclosure with UASP
Quicklinx: 907GWS00 Mfr#: S3510SMU33
Type: Storage enclosure
HD Size: 3.5"
  • Windows 8 (32/64 bits)
37 in stock
£29.91 ex VAT
£35.89 inc VAT
Turn a 3.5" SATA Hard Drive into a UASP-supported USB 3.0 External Hard Drive. The S3510SMU33 USB 3.0 hard drive enclosure enables you to connect a 3.5in SATA hard drive through an available USB port.
With support for UASP, the enclosure performs up to 70% faster than conventional USB 3.0, when paired with a UASP-enabled host controller to utilize the full potential of your SATA III hard drives.
The HDD enclosure offers a versatile solution for increasing the storage/backup capabilities of your computer, with support for SATA I/II/III hard drives at capacities of up to 4TB. Plus, the enclosure features high-quality aluminum construction and a stylish silver design that looks great in any application.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com Hard Drive Enclosure for 3.5in SATA Drives - USB 3.0 - storage enclosure - SATA 6Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Silver
Expansion Bays
1 x internal - 3.5"
Hard Drive Form Factor Compatibility
3.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
Max Storage Devices Qty
1
Product Material
Plastic, aluminium
Power Source
Included AC adapter
AC 120/230 V
Apple MacOS, Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
11.54 cm x 19.15 cm x 3.14 cm
319.8 g
3.5"
Host Bus
USB 3.0
Product Material
Plastic, aluminium
Silver
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
1
ASMedia ASM1053E
Bays
1 x internal - 3.5"
1 x SATA 6Gb/s - SATA power
1 x USB 3.0 - 9 pin USB Type A
Stand
1 x USB cable - external - 1 m
LED indicator, tested with up to 4TB 7200 RPM hard drives
Mounting Kit
Included
Plug and Play, FCC, RoHS
Power Source
Included AC adapter
Power adapter
AC 120/230 V
11.54 cm
19.15 cm
3.14 cm
319.8 g
10 - 90%
907G StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £23.84
907G StarTech.com 2 Port SuperSpeed Mini PCI Express USB 3.0 Adapter Card w/ Bracket Kit and UASP Support In Stock £40.05
907G StarTech.com 3.5in Silver USB 3.0 External SATA III Hard Drive Enclosure with UASP In Stock £29.91
907G StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA Power In Stock £41.11
907G StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £22.66
907G StarTech.com 2 Port Flush Mount ExpressCard 54mm SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £29.85
907G StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps In Stock £32.89
907G StarTech.com 2 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card w/ SATA Power In Stock £15.89
907G StarTech.com 2.5in USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP In Stock £15.35
907G StarTech.com 2.5in Aluminum USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP for SATA 6 In Stock £16.39
907G StarTech.com 1 Port Flush Mount ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £17.38
907G StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 Power In Stock £48.59
HD Size: 3.5"
Price Range Ex VAT: 0 - 50
