This 3.5in SATA to CompactFlash SSD Adapter Card allows you to connect a CompactFlash card to a host computer through a Serial ATA data port - a cost-effective solution that lets you use solid state storage in place of a SATA hard disk drive.
The adapter includes a 3.5in bracket that lets you mount it in the front or rear panel of the computer case, suitable for any 3.5in drive bay or available expansion slot - providing easy access to the CF slot. Once the adapter is installed in the computer, the CompactFlash card can be used as an ejectable, bootable drive - providing full read and write access to the CF card, as if it were a SATA hard drive.
- StarTech.com 3.5in SATA to CompactFlash SSD Adapter Card for 3.5 Drive Bay - card reader - Serial ATA
- Product Type
- Card reader - internal
- Supported Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Microdrive
- Host Interface
- Serial ATA
- Required Bay
- 3.5" internal
- 1-year warranty
- Product Type
- Host Interface
- Serial ATA
- Required Bay
- 3.5" internal
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 7 pin Serial ATA
- Included Accessories
- 3.5-inch bay adapter, rear expansion slot bracket
- FCC, RoHS
- Limited warranty - 1 year
