StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps
Quicklinx: 8ZCMWS00 Mfr#: S3510BMU33
Type: Storage enclosure
HD Size: 3.5"
  • Windows 8 (32/64 bits)
£33.30 ex VAT
£39.96 inc VAT
Turn a 3.5" SATA Hard Drive into a UASP-supported USB 3.0 External Hard Drive. The S3510BMU33 Black USB 3.0 Hard Drive Enclosure with UASP lets you connect a 3.5in SATA III hard drive (HDD) through an available USB port. The enclosure delivers optimal performance with a USB 3.0 connection, but is backward compatible with USB 2.0/1.1 host connections as well.
Enhanced with UASP (USB Attached SCSI Protocol), this 3.5" SATA III enclosure performs up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller. Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP reduces latency, significantly increasing transfer speeds and reducing processor usage to utilize the full potential of your SATA III hard drives.
With support for SATA I/II/III, and large capacity drives (tested up to 4TB) this HDD enclosure is compatible with virtually any 3.5in SATA hard drive, and can greatly increase the storage/backup capabilities of your computer.
The USB 3.0/SATA III enclosure features high quality aluminum construction, ensuring durability.
StarTech.com 3.5in Black Aluminum USB 3.0 External SATA III SSD / HDD Enclosure with UASP for SATA 6Gbps - 3.5" SATA Hard Drive Enclosure (S3510BMU33) - storage enclosure - SATA 6Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Expansion Bays
1 x internal - 3.5"
Hard Drive Form Factor Compatibility
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
Hard drive
Max Storage Devices Qty
1
Product Material
Plastic, aluminium
Power Source
Included AC adapter
AC 120/230 V
Apple MacOS, Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
3.14 cm x 19.15 cm x 11.54 cm
319.8 g
P/N: SVA12M2NEUA, SVA12M5NA, USBDUP15, USBDUPE115, USBDUPE17
3.5"
Host Bus
USB 3.0
Product Material
Plastic, aluminium
Storage Controller
SATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
Hard drive
1
ASMedia ASM1053E
Bays
1 x internal - 3.5"
1 x SATA 6Gb/s - SATA power
1 x USB 3.0 - 9 pin USB Type A
Stand
1 x USB cable - external
Tested with up to 4TB 7200 RPM hard drives
Mounting Kit
Included
FCC, RoHS
Power Source
Included AC adapter
Power adapter
AC 120/230 V
3.14 cm
19.15 cm
11.54 cm
319.8 g
10 - 90%
8ZCM StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD In Stock £29.00
8ZCM StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £24.13
8ZCM StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £22.95
8ZCM StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA Power In Stock £41.62
8ZCM StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 Power In Stock £49.19
8ZCM StarTech.com 1 Port Flush Mount ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £17.59
8ZCM StarTech.com 2 Port SuperSpeed Mini PCI Express USB 3.0 Adapter Card w/ Bracket Kit and UASP Support In Stock £38.08
8ZCM StarTech.com 2.5in Aluminum USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP for SATA 6 In Stock £16.60
8ZCM StarTech.com 2.5in USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP In Stock £15.54
8ZCM StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps In Stock £33.30
8ZCM StarTech.com 3.5in Silver USB 3.0 External SATA III Hard Drive Enclosure with UASP In Stock £30.29
HD Size: 3.5"
Price Range Ex VAT: 0 - 50
