Turn a 3.5" SATA Hard Drive into a UASP-supported USB 3.0 External Hard Drive. The S3510BMU33 Black USB 3.0 Hard Drive Enclosure with UASP lets you connect a 3.5in SATA III hard drive (HDD) through an available USB port. The enclosure delivers optimal performance with a USB 3.0 connection, but is backward compatible with USB 2.0/1.1 host connections as well.
Enhanced with UASP (USB Attached SCSI Protocol), this 3.5" SATA III enclosure performs up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller. Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP reduces latency, significantly increasing transfer speeds and reducing processor usage to utilize the full potential of your SATA III hard drives.
With support for SATA I/II/III, and large capacity drives (tested up to 4TB) this HDD enclosure is compatible with virtually any 3.5in SATA hard drive, and can greatly increase the storage/backup capabilities of your computer.
The USB 3.0/SATA III enclosure features high quality aluminum construction, ensuring durability.
- StarTech.com 3.5in Black Aluminum USB 3.0 External SATA III SSD / HDD Enclosure with UASP for SATA 6Gbps - 3.5" SATA Hard Drive Enclosure (S3510BMU33) - storage enclosure - SATA 6Gb/s - USB 3.0
- Storage enclosure - external
- Bus Type
- USB 3.0
- Black
- Expansion Bays
- 1 x internal - 3.5"
- Hard Drive Form Factor Compatibility
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Supported Devices
- Hard drive
- Max Storage Devices Qty
- 1
- Product Material
- Plastic, aluminium
- Power Source
- Included AC adapter
- Power
- AC 120/230 V
- System Requirements
- Apple MacOS, Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- 3.14 cm x 19.15 cm x 11.54 cm
- 319.8 g
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA, USBDUP15, USBDUPE115, USBDUPE17
- 3.5"
- Host Bus
- USB 3.0
- Product Material
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 600 MBps
- Supported Devices
- Hard drive
- 1
- Processor
- ASMedia ASM1053E
- Bays
- 1 x SATA 6Gb/s - SATA power
- Connections
- 1 x USB 3.0 - 9 pin USB Type A
- Included Accessories
- Stand
- Cables Included
- 1 x USB cable - external
- Tested with up to 4TB 7200 RPM hard drives
- Mounting Kit
- Included
- FCC, RoHS
- Power Source
- Power adapter
- Voltage Required
- AC 120/230 V
- OS Required
- Limited warranty - 2 years
- 3.14 cm
- 19.15 cm
- 11.54 cm
- 319.8 g
- 0 °C
- 40 °C
- 10 - 90%
- Designed For
StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD | In Stock | £29.00 |
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £26.49 |
StarTech.com 2 Port Flush Mount ExpressCard 54mm SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £28.56 |
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £25.19 |
StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA Power | In Stock | £45.71 |
StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 Power | In Stock | £49.85 |
StarTech.com 1 Port Flush Mount ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £19.33 |
StarTech.com 2 Port SuperSpeed Mini PCI Express USB 3.0 Adapter Card w/ Bracket Kit and UASP Support | In Stock | £41.81 |
StarTech.com 2.5in USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP | In Stock | £17.06 |
StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps | In Stock | £33.74 |
StarTech.com 3.5in Silver USB 3.0 External SATA III Hard Drive Enclosure with UASP | In Stock | £33.25 |
