StarTech.com 2x USB Car Charger 24W / 4.8A
Quicklinx: CFQCWS00 Mfr#: USB2PCARWHS
£10.75 ex VAT
£12.90 inc VAT
Charge two tablets simultaneously, in your car. This 2-port car charger lets you charge two mobile devices simultaneously, while you're driving.
The charger can deliver 24 watts of power in total, sharing 4.8 amps of power between both ports. This means that you can charge two tablets at the same time.
The dual-port charger features Smart IC technology, which enables it to identify what type of device is connected to each port. By recognizing the attached device, the charger delivers the optimal charge that's specific to each device.
The charger supports USB Battery Charging Specification 1.2, which ensures compatibility with a broad range of mobile devices, including the Apple iPhone and iPad, the Microsoft Surface tablet, the Samsung Galaxy Tab, Nexus phones and more.
When you're traveling with a passenger, this means that you can charge their device as well as yours, and ensure that both of your mobile devices are ready when you arrive.
StarTech.com Dual Port USB Car Charger - 24W/4.8A White car power adapter
Car power adapter
3.76 cm x 7.05 cm x 2.56 cm
90 g
White
Output Connector Type
USB
12 - 24 V
Voltage Provided
DC 5 V
Car power adapter
3.76 cm
7.05 cm
2.56 cm
90 g
Enclosure Colour
White
12 - 24 V
Input Connectors
Automobile cigarette lighter
Input Connectors Qty
1
Voltage Provided
DC 5 V
Output connectors
Total 2: 4 pin USB Type A
Power Provided
24 Watt
Max Electric Current
4.8 A
FCC, RoHS, WEEE
CFQC StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £11.45
CFQC StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £10.75
Price Range Ex VAT: 0 - 50
